Engine is out.. Motor mount question
BajabossJD
Hey guys.. Making progress.
Couple of weeks ago, the coupler stripped out when I was getting on plane.
I was able to get an Engine Lift for $40 on CL.. Somehow made it work and clear the back of the Baja (air out of tires helped!). Engine is out and I am painting a few things and cleaning up some wiring. I noticed the Port side mount has a gap in it. Looks like one of the two nuts backed off and now there is a 3/8" gap between the two height adjustment nuts.
Stringers feel solid.. see a little dark wood..but have nice grip on the bolts and they need a socket to tighten (Boats a 97)
This in conjuntion to some water in the bilge (Bilge pump burned out and i got stuck in a mild Hurricane while docked) probobly toasted the coupler.
Question is: Should I get new mounts, or just clean up what I have? Locktite them? Not sure what nut moved, but no doubt alignment is going to be a pain now. Is this common on the OEM mounts?
Thanks,
Joe
sharkin95
Re: Engine is out.. Motor mount question
check the mounts for stripped threads, use s.s. 3/8" lag bolts to secure the mounts to the stringers. never seize the nuts and use the lock washers when done adjusting with an alignment bar.
Thanks,
Joe
Nope,... It ain't normal,... There's supposed to be bendin' lockin' tab washers on 'em... No need for locktite...
BajabossJD
Its got the tab washer. Looks like it wasnt seated correctly. Thanks guys!
