Engine keeps surging/stalling
tpenfield
Re: Engine keeps surging/stalling
What have you checked so far? How does it run at higher throttle settings?
I would be looking at distributor, throttle linkages, carb, spark arrestor and intake manifold. You never know if these things are coincidental or cause & effect.
ipete6
i know the throttle linkages are fine, it still does it without the flame arrestor. how would i check the distributer? i checked power to the coil, and changed all the fuel filters. the intake manifold looks fine too. could it be the fuel pump? i feel like after we hit that huge wave that it messed up the diaphragm. It does the same exact thing at higher throttle settings too.
Don S
Start by changing your fuel filters in the carb and pump.
