After a head change and a lot of small others faults , one persists the engine misfire
I checked all, change the rotor and cap, test the coil and distributor, clear and test the cps
check the wires, remove and reinstall the distributor to check the timing, checked cylinder pressure 145~150 all
the engine works great without load, idle and fast ok. But when I tested in water, idle speed in forward ok
however when I put power began a little misfire and chokes until 25 mls.
The image is of the vessel view screen and the fault began with the ignition in on before start the engine
The only thing I didn't check were the injectors.
The engine is a 2011 3.0 MPI EC
I'm stuck with this fault
