engine miss after installing vro to pre-mix pump
ddyk
I have a 98 200 hp johnson that i replaced the vro pump with a stand alone fuel pump. After installing the pump i now have a very noticeable miss at all speeds. This is with the muffs on so i'm reluctant to take it to the lake. I have no idea what I may have done during the install, the bulb pumps up fine, so are there any ideas out there what i need to look at? Any help will be greatly appreciated!
Part # of the pump you installed.----Sourced through a dealer or somewhere else ?
It could be that there is an issue with crankcase compression.----It is the PRESSURE that drives these pumps.-----How did motor behave with the VRO pump ?----Did you find something wrong with old pump ?
ddyk
It ran fine before other than it was trying to run out of gas ( i had to keep priming the bulb for it to stay running) It didn't have this type of miss before. I haven't had a chance to look at the old pump yet.
Chris1956
My '98 Johnny 150HPV6 has an intermediate orifice on the carb or throttle body. They are open to the air. Give it a blast of spray solvent and see if that works. It is a brass tube under the air box.
ddyk
ill give that a try, thanks
Then get rid of that fuel pump.-----Sounds like it is clearly the issue !
