Engine missing in mid range
Thanks for the input last time, guys! Turns out the jets were clogged probably from some gunk coming loose after putting it in and out of my car. Here is a link of what's happening now: https://youtu.be/ipUoPUfWZE0 What I didnt manage to video is that it runs and sounds pretty great at WOT. For some reason though, it seems like its misfiring instead of bogging down. It idles fine too
Prophammer
I looked at your YouTube video, it appears as though you are an electrical wizard , maybe you can make a boat wiring bypass harness with starter switch and try running the outboard independently (only temporary for testing purposes) , that would possibly eliminate any issues with the boat wiring , be careful not to short circuit anything, whether that fixes it or not , upgrade your boat wiring, using marine grade switches and secure all wiring, also mount batteries in boxes to prevent accidental grounding, which could start a fire
