San_Diego_SeaRay
- Nov 9, 2014
- 343
I?ve spent the past few months taking apart, grinding off rust, painting, then putting back together a 1993 Bravo 7.4 engine. The boat is a 1993 27? Chaparral Signature. It?s getting near the time to put the engine back in, and I?ve been wondering about the engine mount holes. There must have been some add?l looseness created by removing the lag bolts. And I?d like to ensure that the engine is as secure or even more so than before I removed the engine.
The lag bolts are about 3? long, and I would say they?re about 3/8?; maybe 7/16?. I was thinking about mixing up some thinned ?peanut butter? resin (thinned w. styrene) w. ?? chop strand and Cabosil. Then pouring it into the old holes, then drilling a pilot hole about ?? and driving the lag bolts back in. My fear would be that the mixture would cure to a ?cold joint? and the whole plug might come out with enough stress. What do you think? How would you approach this? Is lag bolt looseness even a concern?
