Engine mount
Erico624
Is this angle ok to mount the engine mount to stringer? Had to out the wood side by side.
Ayuh,..... Sure,..... why not,..??...
Are you gonna pull 'em apart to free 'em up, 'n clean the adjustin' threads,..??
Erico624
They are cleaned out and loose. Was wondering if this is a ok angle for the base to be at?
kenny nunez
Use your engine lift hooked to the front of the engine.
This will make getting the alinement easy by raising and lowering the engine. Back the adjusting nuts away from the engine bracket. Once the alinement is confirmed raise the bottom nut to the underside of the bracket plus 1/2 more of a turn, this should compensate for the rubber in the mount compressing.
