Engine not starting when warm
bpernia
I have a Suzuki 115HP outboard and it has a hard time staring after we run around and then re star the engine. Always starts from a cold start. any help would be appreciated.
99yam40
How many different 115 Suzuki motors have been built over all the years Suzuki produced outboards?
And which one do you have
Nilsonov
I’ve had this symptom which ended up being a loose carb gasket seal, which lead to the engine being flooded. Had to wait about half hour to restart it, or manually open the throttle when cranking to dry out the engine. Just pull a plug to see if its wet, if so, then youll know that it gets flooded when starting warm.
bpernia
Thanks for the reply your but this engine is fuel injected
You were asked to list a year / model number.-----You must not slam folks for trying to help you
