Engine Oil question (150 Opti)
NFA
I have a 150 Optimax DFI. I've been running it on Quiksilver DFI oil. A gallon of this costs $80 in Canada. Is there anywhere online that sells it for cheaper? Do any of you deal with any online sites for this oil?
Thanks;
SSS
Chris1956
Re: Engine Oil question (150 Opti)
You might check the owners manual to see if you can run non-DFI oil. On some Optis, you may.
NFA
So I looked at oils down in Washington this weekend, and the only difference I noted was that the label didn't say "Quicksilver". The rest of the label is identical. Is this still good to use? I want to make sure before buying obviously.
And ya, it's waaaaaaay cheaper in the states, unreal actually.
Thanks!
SSS
NFA
Anyone?
