engine oil
s1jor
have volvo 4.3, manual says should use sae 30, seems kinda hard to get that oil here, is it a must or will 20/50 be ok or 5/30 or any multi grade oil?????????????????????
Skipster1
Re: engine oil
We need a bit more information.<br />Where do you live? What is the average temperature during your boating season?<br />Why is it hard to get SAE 30 oil? That is the most common grade of oil in the world.<br />If you want to run year around - and the temps range from sub-zero to hot, then you should go with 20-50W or 10-40W.<br />Cheers!!!!!!!!!!!!!
s1jor
Re: engine oil
live in england, hard to get cause none of the shops around here seem to sell it!!!!!!!!!!!!!!!!!!!!!!!!! not all year round cause its to cold in the winter!!!!!!!!!!!
Re: engine oil
will 20/50 be ok or 5/30 or any multi grade oil????????????????????? <br />
Yes.......<br />You'll be Fine......<br />Just use a Quality Oil......<br /><br />I use Mobil 1, 15W-50
goodtimeguy
Re: engine oil
straight 30 would be the best because you would have wicked oil pressure even after the engine is warmed up. but if you can't get it use 20/50. 5/30 is meant for new cars with really tight engine tollerences and the thinner oil gives them optimum gas milage
cobra 3.0
Re: engine oil
I agree...5W30 is too thin. If you use 5W30 you will notice it tends to get consumed and you need to keep topping it off. 15W50 (diesel engine oil) would be my choice.
