engine oil
lions den
do you have to use merc. mercruiser oil in an 1985 i/o 3.7l merc ? why can't use reg. 10w/30 mtr oil?
beezee28
Master Chief Petty Officer
Re: engine oil
you can use straight 30wt oil. for this old engine 40wt oil woulod not harm it.
lions den
Re: engine oil
so you suggest 40wt for my engine...thanks...if a newer engine, you suggest 30wt? is there a reason for 'special' merc. oil ?
crazy charlie
Re: engine oil
Never heard of "special" oil.Mercruiser recommends straight sae30 oil for it motors and sae40 for warmer climates.Older motors seem to like heavier oils.Charlie
oldboat1
Re: engine oil
gotta mention that I've been using Mobil 1 synthetic in my old Chevy 305 for over a year, with good results. I use 15W50, just as in an old Mercedes diesel I run -- had real good luck with that, so switched boat over as well. I think the synthetic lubes better cold, and probably better hot as well with the higher viscosity. (Straight 30 wt. is recommended for the boat -- '77 Chris Craft.)
garycinn
Re: engine oil
Originally posted by lions den:<br /> do you have to use merc. mercruiser oil in an 1985 i/o 3.7l merc ? why can't use reg. 10w/30 mtr oil?
You could use a 10W30, but you might as well put in a 20W. After time that's what it will become.<br /><br />A regular dino passenger car 10W30 engine oil (PCEO) has viscosity improvers. Since a marine engine runs at such high rpm's at longer times than a car the VI's degrade and you are left with an oil that is out of grade -- something like a 20 grade.<br /><br />That is why the manufacturers state to run a straight grade 30 or 40 with a dino. Synthetic doesn't have the same issues so you can run with a multigrade. Merc's 25W40 is actually a blend of 25 grade and 40 grade oils so there are no VI's to degrade. You get the protection of a 40 grade and the cold startup of a 25. Don't know about the ratio.<br /><br />If you wanted to run a dino oil and weren't keen on the straight 30 or 40 grades, you could use a diesel oil (HDEO) such as Chevron's Delo 15W40. It won't thin out of grade like a PCEO will.
garycinn
Re: engine oil
Originally posted by crazy charlie:<br /> Never heard of "special" oil.Mercruiser recommends straight sae30 oil for it motors and sae40 for warmer climates.Older motors seem to like heavier oils.Charlie
Here is Merc's "official" recommendation. It supercedes all previous owner's manuals.<br /><br /> http://www.mercruiser.com/fueloil_recommendation_faqs#1124 <br /><br />Too bad it doesn't reflect their new synthetic blend product ;) -- which doesn't even show up on their web site, but it has been advertised in national magazines.
garycinn
Re: engine oil
Originally posted by lions den:<br /> so you suggest 40wt for my engine...thanks...if a newer engine, you suggest 30wt? is there a reason for 'special' merc. oil ?
Unless you were running in cold temps in the spring or fall I would run the 40 (provided you are sticking with dino and want a straight grade oil). Make sure it meets the criteria of the Merc link above.
LubeDude
Re: engine oil
Garycinn has ya covered, and I agree with the HDDO.
Wart T
Re: engine oil
Service intervals are much more important than type of oil used. Most multi viscosity oil used nowadays is very very good. If you stick with recommended service intervals you will have that oil out long before it breaks down. Volvo recommends automotive multi weight in their engines because they don't sell their own brand of oil like Merc does. Merc does recommend and sell 15W-40.<br />The advice given here is excellent though. No harm in using single grade oil. <br />I have used automotive 10W-30 synthetic in my Volvo 5.7L and drive since 1988. 2000 hours later I am still using both, they are apparently fine. I service the drive and engine religiously so I could probably use el cheapo oil and be fine. I'm a synthetic oil kinda guy so it works for me. I would have excellent results if I used Merc 40W oil I am sure.<br />My point is, worry more about service intervals and less about type of oil.
