I have a mid-90's Evinrude 9.9 that is acting like it has a spun hub. After giving it a little throttle the engine rpms will rise but it will lose most thrust. It will move very slowly at just above idle speed. I researched the forums and marked and checked the prop which checked out fine. Next I thought about ventillation, but the boat/motor was working OK before this problem so I don't think it is ventillation. Everything else seems to be fine. What do I check next?? Any ideas?? Thanks!!:
