badinfluencect
- May 28, 2020
- 5
1989 Mercruiser 260hp fresh water cooled on 26 Carver. I just completed a gimbal housing replacement. Replaced the following:
Complete gimbal housing n gasket
All bellows
shift cable
y-pipe n gasket
flappers
exhaust manifolds n gaskets
risers n gaskets
Tested boat by running with garden hose into raw water pump for 15 minutes. Ran fine stayed just over 120 degrees. When i put the boat in the water and started i noticed small leaks around the rubber boot that attaches to the y-pipe. Hose clamps were tight but i socked them even tighter. Leak went away. Boat idled out ok but started getting hot as soon as I started throttling up. I also noticed she would not throttle up as normal. Would bog out at around 2k rpm. Idled her back She got up to about 220 degrees. I ordered a raw water pump impeller because that is one part i did not replace. Because of the bogging issue however, I don't think that the impeller is the issue. I feel like the water leak from the y-pipe is a symptom. I believe i installed the flappers correctly but i am wondering if having them installed backwards would create the symptoms I have described. I am planning on pulling the boots off and looking in to inspect flappers when I get to the boat this weekend. Hoping someone with some expertise on here can share their thoughts on whether or not flappers can cause what I have described. Also welcome any other thoughts.
Thanks in advance.
All bellows
shift cable
y-pipe n gasket
flappers
risers n gaskets
Thanks in advance.
