Engine parts
boat756
Where's everyone ordering their evinrude parts from? I'm gonna rebuild my carbs and need kits for them,,it's a 60 evinrude from 1986
This site right here and others.----In Canada---evinrudeparts.ca----Or your local dealer.----Avoid using Amazon " really good deals ) as there have been issues.----Why do you feel you need carburetor kits ?-----What is your motor doing / not doing?----Post the actual results of a compression test.---Does spark jump a gap of at least 3/8" on the 3 leads?----Installing a new water pump impeller on a " new to you " motor is almost a must do thing.
boat756
Well first mechanic told me I had 120 across all three cylinders the second guy told me I had 120 120 115. The first mechanic changed the spark plugs and one of the coils and told me he thinks the motor just lived its life and is done,,,,the second mechanic told me he could do a carb job for 450 bucks but wasn't sure if that would help,,,.The motor has a hard time starting ,I had bought some starting fluid and it starts rite up but then boggs out when shifting into gear,,once I get it going it runs great but the last time I took it out(this past weekend) I could only run it on slow speed,,,I feel like there is something wrong with the carbs and I could not afford a newer engine so carb rebuild is my last hope
Model # of your motor ?-----Outline your starting procedure here.-----And are you pushing the key in while cranking it over to start.-----If motor cranks slow the spark will be weak.----So do you have a tested battery ?---Starter motor and cables in good condition ?
boat756
E60tlcds 2 stroke its a 1986 motor,,,battery's are good they charge up2 100%
saltchuckmatt
Boat.....if you answer his questions then your motor might run in minutes.
And that's the honest to God truth.
