Iamwildman
- Jul 27, 2011
- 23
So I just bought this used boat, an 88 Wellcraft powered by MCM165. It started right up and ran great. I've even had it out for a run on the water and it ran way better then expected. So I figure ill do some work on it and clean some things up. I get up under the dash and its just a crazy rat nest of wires. It was basically a 10" diameter ball of wire, black tape and butt connectors. To make a long story short, I've redone all the wiring behind the dash, including new switches and added a new fuse block in place of old breakers. Everything seems to be working fine now with the exception of the engine. It turns over just fine but I but it hasn't even attempted to fire. I believe there are two wires that come off the ignition switch to run the motor. A yellow with red and a purple with red. I've looked over both wires and checked continuity as well. Everything checks out, but its still not firing. The only thing I can think of is that I've connected something to the ground that's causing a constant kill to the engine. What am I missing?
