engine problems
mandm
Please help!
I have a 1987 bayliner capri and it wont stay running.
It will run for a few minutes and then die.
Let it sit fir 15 -30 min. and it will start right back up and run great for ten min.
Please someone help.
JAL51974
Re: engine problems
We will need more info to be able to help like what engine and drive?
What is your maintenance schedule: is it tuned up recently or not, etc.
There are lots of capable people here willing to help, hang in there.
Welcome to iboats!
Joe
SpinnerBait_Nut
Re: engine problems
Please help!
mandm, welcome to iboats.
Please identify your engine set-up and post in the appropriate engine forum above.
Thanks and again, welcome to iboats.
mandm
Re: engine problems
The engine is a 2.3 l omc (ford).
I have changed the plugs, wires, points, condenser and the assist solenoid.I changed the coil with one that I knew worked.:confused:
I also have a hard time going in gear, forward and reverse.
It seems to work fine on land but under a load its not so sweet.
Please help
Its hot and I want to play
