Engine puller loop
SweeperForce
I pulled off my motor without an engine hoist. But I can't seem to lift it onto the stand I built. A couple of guy and myself couldn't bulge the 300 pound behemoth off the ground. So I'm renting an engine hoist. I seen a couple of videos when the engine was lifted by a loop with 3 screws that attach to the flywheel. Where can I get one?
Thanks,
Tom
Frank Acampora
Well, since we don't know what engine you have, we can not comment on how to lift it.
HOWEVER: If your engine does have three tapped holes on the top of the flywheel you can make your own lifter. Simply take a piece of 1/4 inch thick steel or aluminum and drill three holes to match the ones in the flywheel. Then drill the center for an eyebolt that you can buy at the big box store. Be certain to buy a closed eyebolt, not the bent kind as they simply are not strong enough and buy one about 3/8 to 1/2 inch thick. Bolt it through the center hole.
Unfortunately, if you have a later model Force with Mercury ignition there are no holes in the flywheel and you need a special threaded Mercury tool to lift it.
SweeperForce
I have an '89 150 hp which is listed in my signature. I wasn't sure if this is something I can buy or I had to make. I'll hit the depot today a see what it can find.
Thanks a bunch,
Tom
Jiggz
No Title
And here's the lifting ring Frank design.
pnwboat
Here's one that I made to remove a Force 150HP motor that threads onto the crankshaft. You have to remove the nut that holds the flywheel on and torque this on in it's place.
SweeperForce
No Title
I had one of these harmonic gear puller I used to remove my bering race from the lower unit. All I need now is an eye loop ring to screw into the puller. And wala.
Thanks for all the suggestions,
Tom
jerryjerry05
I used a 1/4-20 bolt(hardened) and an L-bracket with a lifting ring from a 350 Chev.
Jiggz
Tom
Just make sure you use high grade steel 1/4"-20 bolts at least Grade 5 but higher is recommended.
