Hi all
I have a 2007 Volvo Penta 5.0 GXI-G with all original components except the raw water impeller.
Problem:
The front of the engine just started making a growling noise. (Similar to a bad idler pulley) It does not growl when cold only after warmed up.
I removed the belt and spun every pulley (cold and after warmed up) and none of the pulleys feel rough.
I used a stethoscope to try and pin point the noise while the engine was running. The belt pulley/alternator/power steering pump area appears to be the loudest.
My questions are if you have the same engine package and have the same problem, and what was it? I understand it could three different parts but looking for a common failure part.
Thanks
Problem:
Thanks
