I recently bought a '78 omc 800 series to restore. The original engine was already out and gone. Stern drive still connected to transom. I have prepared an '87 350 V8 GM to go in it. Is there any reason I can't reinstall just like it was taken out, i.e. w/o removing the stern drive? Also the new engine has elect. ignition w/the coil integrated in the distributor cap. Can someone tell me how to wire to the existing ESA module and interrupt/overstroke switches? Does the ESA module need to be replace just by going to electronic ignition? Also, how hard/$$ is it to replace manual shift cable from the intermediate housing to the upper gear case? Should this be done/adjusted by a technician only?
