Engine removal
HappyPappy
I need to remove my 90 HP Mariner. I have a chain fall to use but wonder if there is a good place on the engine to put the straps so nothing breaks and the engine stays stable.
Thanks
tashasdaddy
Re: Engine removal
there is a lifting eye that can be purchased, it bolts to the flywheel.
Chris1956
Re: Engine removal
Happy, I use a piece of steel plumbers strap which I bolt to the flywheel using two of the 5/16" flywheel bolts. This plumbers strap is then attached to my block and tackle, and the engine hangs from the garage door header.
