Engine removal
87Starcraft
Hello all. I have a 1987 Johnson 110 outboard. Does anyone have the part # for the pulling eye needed to remove entire engine from boat?
tphoyt
Enter your model number on a parts site and look at the diagram for the cylinder and crank case. Should fine it there.
The non power trim ( 6 amp stator ) V-4 models had a lifting bracket on the engine.-----I welded a piece of 1/4 flat bar to an extra flywheel nut for a custom lift device.
