[*]She's running hard at 4600. I'd be a little nervous to run up to 5000. But I'd be willing to give her a try. (time and funds allowing)
[*]Right now using dash tach. Could be off a little I suppose. Has been a really tough summer time-wise this year and haven't been able to do the normal tinkering as I like.
I will say, I know the creep really happens because I can hear it. So the creep itself isn't a tach issue. I just cant prove if it's between 4000-4600 or 4200-4800. Yes important to get test tach.
I'm with Chris, TACHS are frequently off especially at higher RPM..............I'd get another TACH and test to be sure.
[*]It may be water logged, but it happened the first day i put it in the water, so now she'd just heavier. All in all, I see no other evidence of waterlogging. I have the same top end and other handling characteristics as day 1. I have not checked by drilling holes.
Don't drill holes. You have a trailer? go drive your vehicle+ trailer over a scale and get a good unloaded weight. Then trailer the boat to the same scale and get a good weight with NO gear and either an empty or full fuel tank.
[*]Didn't log drive ratio before spring splash. or I lost the info before logging. Same applies to serial number of drive. But I'll look again.
It should be either a 2.20:1 or 2.00:1 drive and should be marked with a sticker.......It's pretty important to know your ratio, RPM and actual speed(GPS) to make any sort of decision regarding props.
If the ratio isn't marked, with the boat on the trailer, remove the spark plugs and slowly turn the engine with the drive in gear and turn the engine 2 revolutions(exactly)........Have a helper observe the prop make either exactly 1 revolution (2.00:1) or slightly less than 1 prop turn, (2.20:1) or slightly more (1.81:1....very unlikley you have a 1.81:1)
[*]I start drive down/in, once it breaks, i trim up to desired attitude, and throttle down to 3900-4100. No tabs usually, but i have started experimenting. The use of tabs has no effect on this creep issue. It planes and hits about 4000 one way or the other, and then goes into slow motion for the next 400 rpms
TABS won't do a lot for your holeshot. up or down until you get moving. At high speed, they increase the parasitic drag and reduce top speed........
[*]Factory swim platform. Finished on underside I believe. Kinda short in my opinion all in all. Might be dragging, but I don't think so.
I did a little reading, there's a problem with some 2000's FV270's. Seems they put that swimstep too low....... Evidently Rinker did come out with a "fix" but they didn't pay for it. I guess owners had to foot the bill on some of them.
The general consensus here is prop. I will focus my attention there. But I'll admit, it won't be until spring test and tune. And depends partially on life schedule at that time. Also, as I stated it's more of an annoyance than a "problem" except that lugging the engine is no good.
Since you're using 22p props, you don't have a LOT of wiggle room. You can go to 20's but that's about it unless you have a 2.00:1 drive. You could go to 2.20:1 and it would help a little.
If I just didn't have this damned job interfering , I'd have plenty of time for boating.:laugh: :lol:
:happy:
I think we ALL wish that!!! I think I am going to retire though
Cheers,
Rick
