NYfourwinns
- Jul 5, 2012
- 14
This is a 98 Penta 3.0 black inboard motor, it was running fine but at one point while cruising at around 3K rpm, I noticed the engine rpm dip a little every 5-10 seconds. It is more pronounced at higher rpm, and if going at 2K it is less of an issue, and it would idle fine. Feels like fuel starvation. Full tank of gas.
I did try to check fuel filter prior to this trip, and took it out for inspection. It looked not bad, relatively clean, no water, but I did mess up one section of filter element where it meets the rubber seal when I was removing it. I can tell that gas is probably not filtering by going through ceramic element but bypassing through the newly created opening in it. Could that create a problem? It did run fine for about 15 minutes before this issue surfaced. New filter element is ordered, and I will be also getting water separating filter per advice of experts here.
What do you think is an issue here? I am new to this type of engine. Thanks in advance!
