tony_cliffy
- Mar 19, 2003
- 182
If I run my 115 4-stroke (Johnson) at 4500 RPMS, does a higher pitch prop suggest higher speed? For example, would a 14x23 prop propell the boat faster than a 14x21?<br /><br />I ask because my 14x23 gives WOT @5600 and 14x21 gives WOT @5900, but I plan to run engine mostly at cruising RPM of around 4500. Wondering (for my stated situation) if sticking with 14x23 might give a faster boat at cruising speed. (I only tested 14x21 at WOT and didn't note speed at 4500 and don't have 14x21 again to test with).<br /><br />Thanks for advice!
