Engine RPMs Fluctuating
platinumedge
Hello All. It's been awhile since I posted. I haven't had my boat in the water for over a year now. I winterized it and "brought it back to life" a couple of months ago - no real issues. However, the engine rpm's fluctuate quite a bit. At idle it runs up close to 3,000, then back down, then back up. When I open the throttle to about 3,500 it bounces back and forth between 4,400 and 3,100. Both fuel pumps are operating good and main filter is new/clean. Note that I was having some problems with raw water pump as it was drawing air. But after I resolved that the fluctuation issue remains. Any recommendations?
Thanks!
And what are you working on? There are many Volvo Penta motors
Check fuel pressure
Check compression
Pull injectors and have them cleaned
Check IAC , replace if the pintle is stuck
