Engine RPMs too high
tfpkrman
I have a 1999 Volvo SX 4.3L stern drive. I have a 14.75 x 21 pitch 3 blade prop. My Rpms are too high. Rated for 4600 but running at 5000 WOT. SPEED IS GREAT. Dont pull skiers but I need to bring my RPMs down. Should I just control with throttle or do i need to change the prop. Its pretty new SS 3 blade. Help please. Don't know what OEM is.
alldodge
The boat tachometer in most cases is not accurate. It may be real close in a given range but not overall
So you may not be turning the rpm's your seeing
Faztbullet
If tach is correct you can have prop sent to a prop shop and have double cup added which will help lower RPM and improve mid to top end results..
alldodge
Don't know which 4.3 it is but most have an upper limit of 4800
