Re: engine running problems
Hi Guys .. great to see some of my old friends helping out in here !! The advice is very sound and accurate that has been given . I would do it in this order ,
1 pull the plugs and turn the motor over to be sure there is no water in the cylinders.
2 Check for spark by using the home made ground system shown above , that is the same as I use .
3 Are you sure the flywheel key is still in ?? these things can come out of the groove when flywheel is installed .
4 if all looks good then go to the first post in this section Sport Jet Info and read it !!! and test the trigger according to the instructions , it looks really burnt on top .
Post the spark / no spark results and the trigger ohm results .. with the help you have in here you will be on the water in no time !!
NEVERMIND
, did not realize who started this thread :facepalm:, read my response to your prior thread and it should help but do try to flush the water out of the cylinders to be sure !!!
Here is what I posted
Getting spark is the real battle on these engines , Yes there is a choke or an auto enricher , From what I can tell you have an eletric choke , the shaft on the back of the carbs , fuel line side , by the vent lines where they attach to the air box is your choke linkage and yes you must choke the motor to get it started cold . See if the ignition key pushes in while in the switch , if so that is how you activate the choke . You should be able to hear them click closed
