I have a 1984 Johnson 75hp that runs well very well..SOMETIMES! The engine will start right up and idle well. When at full throttle(sometimes) the engine will automaticly back down as if I had back off on the throttle. If I manully back off on the throttle when this occures it will "catch up" and run well. Today when I had it out on the water, the engine was running great, I had it at full throttle came into a no wake zone and manully throttle her down, after passing the no wake zone and throttle her back up, the engine would only go at about have throttle even though I had her at full throttle. I backed off on the throttle to idle (then it stalled but started right up) and tried it again with the same results. The engine still would run only at half throttle even though throttle was wide open. When I got her home out of the water the engine started right up and was able to throttle wide open, I tried to diplicate the problem but seems to happen only in the water. I can't figure out why it will run well for awhile and then poorly,back and forth...Any Help would be greatly appreciated.THX
