own a sea ray with v8 305gm mercruiser, it's been running hotter than usual, just replaced water pump(lower drive and circulating engine pumps) what would happen if i take the thermostat off, just like in older cars i do most of my boating in temperatures above 90 degrees, water temp probably 70-75 dgrees, is it a most to have a thermostat i a standard cooling system(not closed system)thanks,Ed
