ChooChooSnakeMan
- Dec 11, 2023
- 69
Hi Everyone, I'm looking forward to getting boating season kicked off here soon and getting the Ebbtide 2660 Ztrak with an 8.1 Volvo Gi-J in the water for the first time. I've read a lot of posts in various places about water injestion for these engines. I see some statements that are confusing, at least to me. Some statements seem to say that it is only a concern for engines operated in salt water which mine has not nor will be. I also see that maybe there was a model year that the problem stopped. My engine is a 2011. I also see that some people say that they run the engine out of gear at 1500 - 2000 rpm for 20 seconds to heat the exhaust and evaporate any condensation and they shut the engine off with the key while running 1500-2000 rpm. I want to follow the right procedure. I note that my engine manual says to not turn the engine off at any rpm more than idle and I can see where shutting down at high rpms might create problems with sensors. So to all you VP gurus out there, what say ye? What has been your practice? Shut off at idle speed or shut off with higher rpm? Or maybe you do something different. Maybe it was only a problem in salt water or prior to my model year of 2011. Your input is appreciated. Thanks
