Murph1966
- May 27, 2017
- 5
Back story: Twin Engine Sea Ray 290 SLX. Port engine has been running a bit hot at times over the past year even after installing new water pumps, etc. Not consistent but at higher rpm. Operates fine at low and mid range rpm. After a day on the water with lots of people on swim platform we returned home. ( I've read that too many people in the back of boat can cause water intrusion) Engine ran fine for the 20 min journey back home. At docking and at idle the engine quite. Attempts to start did not work and the engine chugged a few times then just a click. Parked the boat and called our mechanic who was too busy to get to our boat right away. Boat sat for a few days before they sent a tech out to assess the problem. He pulled the plugs and found water on one of the cylinder heads on one side only and only in one cylinder. He was able to manually rotate the engine but it was stiff.
Boat then sat for two weeks waiting for the boat shop to get to us. Neither the tech or the shop owner/mechanic never put any lubrication in the cylinders or recommended that we do so. Which, as I've now read, is critical in preserving the engine! Seriously? Boat is now at the shop and they found a cracked exhaust manifold but cannot get the engine to rotate manually in either direction. They sprayed some kind of corrosion eating lubricant into the cylinders (Krull? sp?) and it has been soaking for several days with no luck.
I'm really disappointed that this very reputable shop did not advise me to lubricate those cylinders while it sat. I've read here that they should also consider removing the starter, but they haven't done that yet either even though they do know its shot. Apparently they found parts of the starter in the bilge! I really don't want to have to pull this motor.
OBTW, the starboard motor is operating just fine. I've never had any issues with this motor. Mechanic did say that that motor has had both exhaust manifolds and risers replaced sometime before I bought the boat last summer.
1. What do you think is the cause for the water intrusion? Cracked exhaust manifold? Considering that the starboard engine is fine I'm doubting it was too many people on the dive platform during the day.
2. What would cause a starter to come apart?
3. Should they remove the starter and then try to rotate the engine? I've read here that this could be a seized starter that could lock up the rotation?
4. What other options are there to free up the engine before having to pull the motor?
So, I made the mistake of not researching this myself soon enough. That's on me, but to not tell your client to take critical steps in preserving the engine is really disappointing.
Thanks in advance for all your help!
