Thank you members in advance for any suggestions.I own a 1998 20 foot Sea Ray with a 305 TBI motor and a alpha outdrive.This past week my boat overheated due to the exhaust manifolds being in bad shape.I replaced my manifolds and elbows and tried to start the boat.It would only start on the muffs with a little throttle.Once warm it would idle but not right away.I have since replaced the TPS,IAC,and the IAT.I have checked the ECM for error codes and there are none.This season I noticied that the alternator would not look like it was charging until the tach read about 1500 RPM.I was wondering if this is normal.The voltmeter would jump from around 12 to 14.7 volts right at 1500 RPM.I'm wondering, if the alternator is bad would the motor start for an instant then not have enough voltage to keep the ECM powered up.Thanks again for any help.The dealer listed the price of a new ECM at 2600 dollars OOUuCH
