Re: engine stalling when using trim. please help!
My suggestion is that there is improper wiring that is effecting the voltage to the ignition circuit while the trim is being operated.
So, you are getting a substantial voltage drop at the ignition circuit. Time to check the wiring for bad/frayed connections, and improper alterations.
