Hello,
Writing from new caledonia with a question or 2.
Lately I got a boat from a friend ( sundancer 240) with a new engine (MAG MPI 300Hp). The sterndrive was damaged so I had to change it from a BIII to a BI ( a sterndrive I had from a previous boat).
However, I have a small problem.
There is a "snap" at the passage of reverse gear or switching
between forward and reverse gear, and sometimes the engine stalls if I do it gently. I have to be quick to avoid a stall.
Would you guys know the reason?
Thank you
Rod
Thank you
Rod
