Engine Stalls Out (125 Force I/O)
sjphilp
Hey guys....<br /><br /> I was out on the lake about 2 weeks ago and she ran like a champ. However, after she was warmed up (@ 30 min) when I would go from an idle into gear she would stall out? I was thinking maybe I should increase the idle rpm just a little? Any suggestions or thoughts on the cause and/or solution?<br /><br />Thanks for your time,<br />Shawn
SpinnerBait_Nut
Re: Engine Stalls Out (125 Force I/O)
Welcome to iboats.<br />Let's get this to the Force forum for answers.
roscoe
Idle should be 800-1000.<br />Check compression.
sjphilp
Roscoe,<br /><br /> Thanks for the info I will do the compression test today and verify the ERPMS..... I also took a look at some other posts and this seems to be a common problem with Force Engines.<br /><br />Shawn
noshelter
Hey Shawn, just wondering if you've got any updates of your stalling problem there? I (may) have a similar problem. If I put it into forward slowly at idle, sometimes it conks out. But if I crank it, like a hole shot, it's usually fine. Could this be an idling problem?
