Engine stalls when accelerating in forward
Laneman25
Going to look at one for sale, it's a Four Winns with 5.0 Volvo sterndrive. Seller says engine idles fine in reverse, neutral, and forward, but when accelerating, engine dies.
If it's carbureted, most likely the carb needs work and the accelerator pump circuit is plugged
However without trouble shooting, it's only a guess
Start with a compression test
See if you see two fuel streams when applying throttle
Laneman25
Thank you Scott, will check accel pump. Was also thinking float level in carb or fuel pickup screen inside tank
Wouldn't be float level. And pickup screen is only a remote chance
Start with compression test, check everything
