My 1982 Renken has a 4 cylinder 120 hp OMC engine that won't turn over / start. The last time the boat was in the water the engine quit and refused to turn over or start again. I have a new battery in it (the battery connections are tight), I pulled the starter and had it rebuilt, and had the slave solenoid tested by an electrical shop and it is good. The slave / starter solenoid makes a load click when the ignition is turned but nothing else happens. The throttle is in the neutral position when I try to start it but no go.
Any ideas as to where to go next in my trouble shooting?
