Engine stops when up to temp
henry1357
Hi everyone
Have just replaced the long block on mercruiser v6 4.3 vortec, but when I'm trying to adjust the timing the engine stops and won't start after about 10 mins running.
I'll leave till the next day and it starts fine again for another ten minutes and then stops again.
Seems to only want to run when cold.
Used all the ancillary parts from previous engine which were in good order, reason for new block was dropped valve and ruined cylinders and pistons.
Was running perfect before this.
Any ideas would be much appreciated
Regards
Henry
Re: Engine stops when up to temp
Hi everyone
Regards
Henry
Ayuh,.... When it Dies,.... Does it loose it's Spark, or it's Fuel,..??
You've gotta check to see what's missin'....
henry1357
Hi thanks for reply
I believe its electrical problem a the carb is getting fuel
Regards
Henry
Hi thanks for reply
Regards
Henry
Ayuh,.... Then You have to figure out where it's got Power, 'n where it Ain't....
Get a test Light, 'n follow the testing found up in the Adults Only section, at the top of this forum...
henry1357
Hi are you referring to the TroubleShooting engine starting system thread
As I said engine runs but stops when its up to temp 175
Regards
Henry
henry1357
Also I have just remembered that when brought new spark plugs the shop didn't have the same ones as the original engine so gave me an equivalent.
Same reach gap etc
I believe the original were Ngk but the shop in spain doesn't sell them
Could this be a problem once the engine heats
Regards
Henry
888
Id be looking at the Ignition module.
dingdongs
if the oil pressure switch is faulty it will stop the supply of 12v to the fuel pump.if you can rig a multimeter or a bulb to see where your losing volts it may tell you whats playing up.if it is the oil pressure switch you can use a jumper wire temporarily to c if this the faulty component.(between two wires that connect to the pressure switch and its near the oil filter.)if you cant start till the following day this may be the fault.
if not see if the coil is cooking itself.
henry1357
Oil presure switch was faulty and I have made a jumper wire for the time being
Just can't figure out why it runs fine then stalls once warm
500dollar744ti
so when this happens, is there spark or is there not?
