Engine Storage
Adam76
Well what was supposed to be the normal winterizing process turned out to me having to due alot more work once the drive was pulled. I needed to replace the gimble housing so yesterday I pulled the engine, and realized I'm going to have to due some work which is alot easier with the engine removed. So the engines out and will be kept inside. What due I need to due to the engine since its out and going to be stored for awhile. Thanks. The engine is a 94' 5.7. Thanks
Re: Engine Storage
Ayuh,... Drain ALL the water out of it, 'n squirt some oil into the cylinders...
Adam76
Re: Engine Storage
Thanks should I use the fogging oil in the cylinders.
