engine suddenly dies at cruising speed
intrepidvoyager
Have an odd situation .. .... boat has 1990 big block Mercruiser with new Bravo leg and half closed cooling system...boat will run great for hours then all of a sudden at cruising speed engine dies ...will not immediately restart, however if left 10 mins will restart and all is normal again ..... back at the dock coolant temp, voltage, oil pressure, 1/4 tank fuel ..all normal.......also same fuel used next day with no problem .. I am wondering if anybody else has experienced this odd situation?......or any ideas ....... this has occurred twice within 2 weeks.
Thanks.
Re: engine suddenly dies at cruising speed
Ayuh,.... During those 10 minutes,.... Is it lacking Fuel,..?? or Fire,..??
slasmith1
check your tank vent first.
intrepidvoyager
Tank vent ...now that is a good possibility .....also will check fuel delivery although think we put a new fuel pump in that boat last summer ...I'll check anyway ...
Thanks guys !
