Patient - 1969 Sea Ray 185 with 160 inline 6 (bad) and old one drive (serial #2614325) I've been told it was good.
Donor - 1979 Marquis with 165 inline 6 and second generation one drive (serial #5359131). I've had this combo on the lake and it runs good. Rotten transom and floors...
So far I've gotten the 165 mounted in the Sea ray, so much for the easy part...
The electrical connections on the two boats while being the same size, have a different pin configuration. 160 has 2 large pins and 6 smaller pins, 165 has 3 large pins and 6 smaller pins with one of the smaller pins inside the main circle.
The 160 also has two large resistors mounted just behind the connector as well as a plastic bit with fins mounted to the transom just next to the blower that has 3 wires going into the harness behind the engine. The wiring diagram for the Sea ray (many thanks to an original owner who didn't throw anything away) shows this as the transistor voltage regulator.
Seems the best thing is going to be moving the harness from the 160 over to the new motor. Seems easier if practical to move the connector...
Any cautions, ideas or experiences appreciated before I move forward...
Thanks,
Steven
Thanks,
Steven
