Engine swap ....merc to Volvo
Galbraitro
Hey all! I’m a newbie to the site, but a long time reader that could definitely use your expertise!
ive got a 1995 searay Sundancer 370 with 7.4 mercs. They are coming out as they are tired, and I have access to two 2006 Volvo 8.1L engines. I understand that the the engine mount pattern is the same, but will these engines bolt right up to my transmissions? What will I need to replace/convert to make this work? Or should I look for mercs again...
thanks in advance
alldodge
I looked up both motors and rear bolt pattern are the same
Merc uses flywheel housing 865657A04
VP uses flywheel housing 3852831
496 Couplers and the flywheels are different then 7.4
Merc coupler bolts to outside edge of flywheel
VP coupler bolts to crankshaft along with flywheel
Without more info, it appears just use your coupler and bell housing, and replace the crankshaft to flywheel bolts to the size Merc uses
Also not: the 496 uses different exhaust manifolds then the 7.4
Head exhaust pattern is same between 7.4, 8.1, and 8.2 so the 454 exhaust can be migrated to the 496s. Hoeever the 496 exhaust breaths better
Flywheel bolt patterns are the same, however the 496 uses metric fasteners
Bellhousing pattern is the same, however the 496 is M10 vs the 3/8
alldodge
There is sure enough info out there stating differently. Something about require drilling of new holes to make them work
