you can use the short-block and heads from the S-10 (not a complete motor)
you will need marine head gaskets and brass core plugs
all other things bolted to the motor must be marine.
this includes:
water circulating pump
all rotating electrics (starter, alternator)
intake manifold and carb
front brackets, pulleys, accessories
fuel system
ignition system
oil pan
if the S-10 had a manual trans, you can use the flywheel, if not, you need to swap over that too.
highly recommended to replace the coupler if the motor is out.
i suggest new manifolds and elbows.
