engine swap
Rich Novak
1972 omc 225 sterndrive electric shift.
Will a marine 350 engine fit on the o/d.
And what is involved to make the change.
I know how to r&r the engine.
Thanks,Rich
Thanks,Rich
Ayuh,... If the 225 motor is a V8 Chevy, it oughta bolt right up,....
If the 350 is newer than '86, yer gonna have issues findin' a coupler that'll work,....
your OMC 225 is a 350. its at 225 hp.
Howard Sterndrive
another option is a new or used GM 290HP/350 Crate motor- they use the old pre-1986 crank bolt pattern
Rich Novak
Any thing specific I should tell them if I should order a 350 short block.
