Re: engine swap
nope, all the control cables will be different, and the wiring harness will also not fit. To swap them over (bolt/unbolt) would be easy enough, but to use the same control system would be asking for problems. It is not that hard to swap the wiring harness and controll box over, although just remember that the wiring harness includes trim/tilt meter, tacho and hourmeter, so you'd need to look at the holes in the dash and compare for size etc.
