Engine Swapping
ocscuba
Hello, I have an OMC GM 350 I/O engine and would like to know what I would need to do to swap it out to a ford v-8 I have in another vessel.<br /><br />Thanks,<br />Capt'n Dan
Re: Engine Swapping
Is this Ford Already Dressed in OMC Clothing ??????????<br /><br />Either Way,<br />You'll need to remove Everything Forward of the Rear Motor Mounts,<br />And replace it with the Ford Stuff..........<br /><br />It would be Simpler, Smarter,+ Cheaper(in the long run)..........<br />To Install a brand new GM Goodwrench Pick-up Truck Long Block.........<br />If you have Closed-Cooling, It'll run Perfectly As Delivered.....<br />If you run Raw-water, Just pop in a set of Brass Freeze-Plugs.........<br /><br />BTW,<br />Welcome to iboats forums.................... :D
