Re: Engine Tank Oil Pump
test the switch in the engine tank as per the service manual. if the switch is good replace the module. if the carbs are swimming in oil it will cause some low speed problems.<br /> fix the oil problem first then change the plugs and retest<br /> good luck and keep posting
