I have a 2002 Four Winns 298 Vista with twin 5.0 liter Gxi's with duo prop out drives and a raw water cooling system. The engine temp on STB engine runs between 160 and 170 on gauge. (perfect) My port engine however runs between 110 and 130. After reading previous posts, I yanked off the Thermostat housing and sniffed around for impeller chunks. I unscrewed the 90* elbow on the bypass and sure enough found a chunk of impeller. Fished out the chunk and did a thorough search around the housing for more peices and found none/ Placed a new o-ring and thermostat in it and I am still running on the cool side, still topping out at 130. Any ideas on what to start with next? I verified gauge with a heat gun and the gauge/sending unit are not the problem. Thanks.
