This may sound dumb but can an engine run to cold? I just put a new thermostat in (the manual called for a 140 degree) I ran it with the muffs after and the temp got to about 130, i took it to the lake and ran it hard and the temp gauge was only showing about 120 after about a half hour. The manifolds and risers were warm to the touch but not hot (which I think is normal)
Keep in mind ijust replaced the impeller and the lake water temp was about 50-55 degrees.
Thanks....
Thanks....
