I have a '95 Caravalle 19' boat w/ a 5.0L Volva Penta engine. I bought the boat used, with low-hours. I am having trouble with idling.<br /><br />When I crank the engine, the engine will start, but it will die out after several seconds if I do not quickly put it into gear, and give it a large amount of gas. Even if I simply start the engine and put it in drive, the engine will sputter out without a sufficient amount of gas. I have no problems once I begin moving. Sometimes I am only able to start the engine by sliding the throttle stick out, pumping it several times, and cranking the engine. Even then though, once I return the throttle stick to the neutral position, if I don't quickly give it gas, it dies.<br /><br />Is this a carburetor problem? Or is it simply that the idle is too low?<br /><br />Do you need any more information?<br /><br />Thanks!!!!<br />-shack
